If it's burning the correct quantity of gas the heat energy must go somewhere. Either the DHW flowrate is too high or heat is going to the rads. Feel the pipework at the rads...are they getting hot when the hot water is being drawn.
You seem very keen to rush into changing instead of letting us identify exactly whats wrong with your boiler.
All you need to do is turn on a hot tap and measure how long it takes to fill a pot, bucket or other container.
Then we can calculate the flow rate and compare it with the boiler's capabilities.
Tony
The thing is, in the time we've been talking on here and the several parts you've fitted, a registered heating engineer (not plumber) may have been able to sort it. Anyways.... check the flow rate as advised, post back results. Just to clarify, you need to measure how many litres of water is passed in a minute.
I cannot understand why you cannot spend just five minutes measuring the flow rate.
I am not asking you to adjust it onmly to measure it.
To adjust it all you need to do is to NOT turn your basth tap on full.
You seem fonder of your computer than just doing a five minute check.
Tony
