- Joined
- 18 Mar 2008
- Messages
- 1,491
- Reaction score
- 1,090
- Country
Maybe I'm missing something here. Are you having problems maintaining your property temperature to a constant level? You seem to be pre occupied with the operation of the appliance and controls and how you think it should work.
I have a modern highly insulated house using 15 radiators with a heatloss/load of 10.5 Kw. The system is very common in modern build with 10mm drops to all rads from a 22mm reducing to 15mm circuit mainly within the 1st floor. It has a fairly high resistance. With a correctly adjusted bypass and balanced system I really have no problems with the 430. With the pump overrun adjusted to suit the property it is ticking over at a very consistent 21C.
I have fitted and commisioned many WC systems in domestic and commercial situations. I have attended many more 'faulty' WC controls for Vaillant UK Ltd, only a handful are really faulty. I believe your problem is sortable, but I don't think you've had the right engineer diagnose the issue yet, if there is an issue.
Cheers
Cheers
