I agree with you there. The 937 only goes down to 12kW so if the OP needs 24kW the boiler will stop modulating when the outside temperature is above 10C.Most boilers will modulate down to about a third of their maximum power.
That may sound OK to you but the problem is that a 37 kW boiler typically only goes down to about 12 kW and thats more than most heating systems usually need for 95% of the year.
The boiler then has to on/off modulate which is not so efficient. Its one of the problems of a high powered combi which is specified for DHW output.
One of the reasons I suggested the Remeha boilers is that they can all (combi, heat and system) modulate down to 6kW, which is equivalent to an outside temp of 15C.
As the OP has picked up, but Tony seems to have forgotten, most decent boilers can be range rated. So a 30kW boiler can be set to a max output of 24kW when appropriate.
