Valiant combi blockage or pump broke?
31 May 2015
London
My hot water has stopped working, when hot water is selected the boiler (valiant turbo max plus 828e) shows the temperature shoot up on ignition then makes nasty noises like a coffee machine (boiling water/steam) whilst the pressure gauge jumps about and the ignition cuts out (I guess as protection for overheat) and the water temp drops to cold again. I'm guessing it's either a blockage somewhere or a pump that's knackered. What are the likely parts that could be wrong? I have noticed recently that the hot water temp hasn't been its best when running baths, would this point towards a blocked heat exchanger somewhere?
Any relevant advice is much appreciated
