Hydroxycholoroquine? Bleach? No, they haven't.remember last year when trump had it and everyone calling him a lunatic for the drug he was taking for it ...its Just been approved by NHS
see there you go did he mention bleach in any way nope try listening to the actual speech bit like straight away people laughing when he said about using light .Then people pointed out that light is used to treat various health conditions including cancerHydroxycholoroquine? Bleach? No, they haven't.
Regeneron, which you probably are talking about was experimental and so was discussed as not necessarily a good idea but I don't think anyone said he was a lunatic for that. Unethical because he got access to a drug that wasn't available to others, yes.
It was a gamble, that it paid off doesn't mean it was a wise gamble to take, or that gambling on something else just because it hasn't been approved yet is automatically a goo idea.
Yeah, the light thing was even worse. Also not approved on the NHS.see there you go did he mention bleach in any way nope try listening to the actual speech bit like straight away people laughing when he said about using light .Then people pointed out that light is used to treat various health conditions including cancer
you do realise UV light is being used to kill the corona virus in various situationsYeah, the light thing was even worse. Also not approved on the NHS.
"Hey, I've got a potentially fatal viral disease that attacks the lungs!"
"No prob, mate, I've got some horse-worming tablets here. They'll see you right."
Barmy crackpot.
So is bleach. Bleach is excellent at killing germs and viruses. He asked if we could bring the light inside the body. Sticking a UV light up your rectum is unlikely to cure Covid. Bathing under a UV light strong enough to decontaminate your skin is likely to give you sunburn.you do realise UV light is being used to kill the corona virus in various situations
https://www.ajicjournal.org/article/S0196-6553(20)30756-2/fulltext
And if you actually listened to the interview he was asking if it was possible
It isn't new, but some of the suggested dose regimes are new. Either for a longer time than previously studied or in higher doses. Or both.
Plus it is now going to be used with other medications that won't have been given with it. Dexamethasone, Tocilizumab, Regeneron, Remdesivir (although that might drop off the standard of care as it seems to be ineffective) etc. I don't know the side effects of each, or the possible issues with taking both Ivermectin and the standard of care, but some medications should not be mixed.
Are you making that up?The majority of Ivermectin studies suggest it is to be used in early stages prophylactically.
Sure, so you test. You see it work, you use it if it's all you have. Several drugs which would be nice to have aren't available in many countries.At that stage there is no cytokine storm, in fact drugs that have been shown to reduce or prevent cytokine storms are dangerous if you use them too early as they suppress the immune response. Even when there's a plausible mechanism, like Hydroxycholoroquine, it doesn't always pan out. In fact normally it doesn't pan out, there are far more potential treatments than effective treatments.
No-one is suggesting that IVM is a "cure" either. Paracetamol is used as an anti-inflammatory, it's one of its effects.As a treatment for pain where it does have approval, sure, but no one is suggesting that it is a cure for Covid.
Yes, the Together Trial was hospital based (so not prophylactic). They dropped it because it showed no benefit.Some of them are not in those categories, have a look... The link I gave provides details of a lot of trials.
I don't have time to read through 60+ trials. Together might have encountered negative side effects, when they publish full results on the Ivermectin arm it'll be worth a readAt leasty some of the people doing trials with it in hospitals would have reported problems as well as successes. Perhaps you'd like to cite them.
Your link, or an ivermectin site that was linked from it.Are you making that up?
What's your evidence?
It is completely relevant. There were a large number of small low grade studies that showed potential. That's exactly how it should be done. Then it went up to the well designed, funded and scaled studies that showed Hydroxycholoroquine caused more harm than good. It killed people in the trials, thankfully not many because they were well run, but it was worse than nothing.Sure, so you test. You see it work, you use it if it's all you have. Several drugs which would be nice to have aren't available in many countries.
Hydroxycholoroquine was used early on - ask Tom Hanks, it made him ill. Nobody much said it was working well so it's dropped. That has no bearing.
You might not be, but people are. Paracetamol is not an anti inflammatory. Seriously, come on.No-one is suggesting that IVM is a "cure" either. Paracetamol is used as an anti-inflammatory, it's one of its effects.
In that it's the same as IVM.
I doubt it. It's more expensive than bleach and surface contamination is a tiny part of Covid transmission. The major method of transmission is airborne. Unless you had UV walls between people it's not going to help, and the Ozone it produces would make that dangerous.Short wavelength UV is good for killing virions, and bacteria, because it has powerful photons, which do not penetrate the skin at all - even the moisture layer on the front of your eye. EMitters aren't particularly cheap/easy but I expect we'll see a lot more of it..
Surely they can't all be faked?
(sorry no link) which say no, it has no useful benefit.
Ivermectin: Something of a summary here, several pages:
