- Joined
- 22 Aug 2006
- Messages
- 5,854
- Reaction score
- 718
- Country
I doubt it. It's more expensive than bleach and surface contamination is a tiny part of Covid transmission. The major method of transmission is airborne. Unless you had UV walls between people it's not going to help, and the Ozone it produces would make that dangerous.
Where they are being used it's not to use UV to kill the virus, but to generate Ozone. The science fiction trope of having UV lights to sterilise you is mostly myth.
https://nation.cymru/opinion/why-we...e-dangerous-disinfection-machines-in-schools/
You doubt it = you didn't look, and guessed wrongly.
Just do a search on "UVC to kill microbes" and you'll get a page of hits.
It's being used in air circulators.
As well as most sizeable garden ponds for years - not too much ozone underwater, eh?
"The science fiction trope of having UV lights to sterilise you is mostly myth." Please don't write nonsense.
Paracetamol you're right - first hit says "Paracetamol has practically no anti-inflammatory effect". Looks like it may have been downgraded but the point is still correct - you can't say that because a drug's main/intended purpose is X then it can't be used for Y. CF Viagra. Yes it should go through trials, but if it's been in a trial at all - which IVM has, safety has been examined.
You're wrong about paracetamol being suggested as a treatment for covid - that was HMG's initial recommendation.
"Ivermectin hasn't been demonstrated to work yet." Not true. Maybe not to your satisfaction. You made things up about ' majority of the trials suggesting it's used in early stages prophylactically ' (an oxymoron) so I can only assume you haven't read much, ans are biased.
"Antivaxers are
using it instead of proven treatment" Link please - but so what if they're that stupid. In countries where it's been used most , vaccines weren't available. Sounds like you believe in a conspiracy, or an anti conspiracy conspiracy, which has no place here.
"If it were being used responsibly (in addition to proven treatment and vaccination as part of a clinical trial) then I'd have no issue with it" This is where I came in. It has a number of trials in respected institutions which need explaining. Some are corrupt, as I said, (so JohnD has gone off making a meal of it, to no effect). Everyone, including Pfizer, trumpets their own results as the most important
It appears people on this forum make things up with no basis, but I wouldn't expect it of every institute which has done trials.
As for the Roman et al review - it's clearly biased as hell. You will eg find where it says that no benefit was found for some aspect in X number of cases - therefore are we to assume there was a benefit in the rest and it would rather not say?
