The vent pipe connection should be vertical. Feed doesn't matter. I don't think it matters how close you are to pump inlet, but of course the feed connection will be closer than the vent, and the two should be close to each other.
Just to clarify. I have a vertical pipe to above the header tank but I'm not sure about the vertical or horizontal positioning of the connection to the system.
