I am trying to add an additional PIR to my system to cover a new room in my extension.
I have wired from PIR location back to control panel.
This will go as Z6 on my system.
I have removed the loop jumper from Z6 and used white/red in here and also in the Relay / NC ports on the PIR end.
I have also wired Green and Yellow to Aux + and - at the both ends.
I have tested across the +/- on the PIR with a multimeter and have 13V.
However, no LED showing on the PIR and if I do a walk test, Z6 shows as permantly activated.
Anything else I should have done, (ie, does the control panel need programming to accept the zone?)
You can probably tell from my terminology that I am a DIYer and not an engineer!
What to do next?
What to do next?
