Hi
A number of years ago EDF changed our electric meter.
Following that, we started to receive higher bills that we were not used to.
They sent out an engineer who rigged up another meter - so both run in tandem.
for around 2 weeks. Result: both meters matched. So there was nothing wrong
with our EDF meter BUT presumably the engineer would have used a matching meter,
that would have been "rated at 800 imp/kWh"
Over the years before the meter was changed, EDF and Southern Electric would often
refund money because our usage was lower than what the monthly DD was for.
We have tried all the regular things to try and find out what appliance(s)
are using so much.
Last week I brought an excellent unit that monitors everything,
the "geo Minim Energy Monitor"
It works by sticking a self adhesive black light sensitive sponge around/over the
flashing red light.
It reads the flashes, and in real time displays what the usage is indoors on a small monitor.
It is only after fitting the light sensor that I read printed next to the red light,
800 imp/kWh - I didn't have a clue what "imp" is - but since found out it stands
for the amount of "impressions" before registering that '1kWh' has been used.
I've also read that 800 imp/kWh meters are rare, and that most meters in
the UK record 1,000 impressions - before registering that '1kWh' has been used.
HERE'S MY QUESTION
So if our meter is working with 800 impressions per kWh
is it possible that our meter is designed to register each
kWh SOONER THAN A METER USING 1,000 impressions ?
Just trying to think logically here - inasmuch as 800 imp/kWh
will register so much sooner than 1,000 imp/kWh
Just a somewhat desperate thought!
Many thanks in advance.
Stephen
are using so much.
flashing red light.
HERE'S MY QUESTION
Stephen
