no.. i did say that earlier
what the zone valve?
If the boiler has weather compensation and it is correctly set up, it will not need to be told via an external demand to supply heat - it will know when and how much.
If you are just adding underfloor to one small area I fail to see the need to have a all singing all dancing system, simply addd a Danfoss RTL valve (Return Temperature Limiter valve) simple, easy, cheap and it works well, I would say putting wood on top is not best, you would be better with stone to increase the heat output, wood would reduce the performance as it is an insulator
www.danfoss-randall.co.uk/PCMPDF/VD.UI.A1.12.pdf[/QUOTE]
These are great, however be careful you get the one to suit your floor area.
Split ASHP are great for conservatories, cheap as chips & work like a dream.
If you use a Viessmann mixer
