Wales becomes Trumpton
It works.
If it worked, they're would be little death and serious injury (because drivers would be obeying appropriate speed limits).
But id prefer proper enforcement against those that don't obey 30 etc.
I agree.
Good chance it's those that object to 20 the most too
Exact opposite, I'd bet: those that object to 20s are most likely those that see themselves as ultimately abiding by them (hence their objection).
Speed does not kill. Rapid declaration or acceleration kills. The reason why both happen needs to be addressed reduce road casualties.
So is that bit wrong ?
The very next sentence says… Difference-in-differences analyses showed no statistically significant differences between the intervention and control sites over time for road traffic collisions.
in other words the reduction was the same as the control site.
Great if you ignore the fact I highlighted
Then you misunderstood what you read. The intervention site has a new 20 mph limit. The control site does not. Both performed similarly.
they therefore concluded the 20mph limit made no difference. This is consistent with other research. Without self enforcing features, it’s just a sign on a post.
I personally think speed limits should be the max safe speed in all condition, allowing drivers to observe and be free to choose a lower speed when the conditions dictate. They should not be a speed that assumes you are driving blind and will mow down every possible pedestria.
but what do I know.
The facts from your link that I posted were quite clear in their own right.
You are cherry picking to make a case for something that only you seems bothered about
The facts were clear in their own right.
That you have to find more information doesn't change them.
Yes I agree.
But because some people don't stick to limits the easiest way to slow mist people down is to lower the limit.
It works. But id prefer proper enforcement against those that don't obey 30 etc. Good chance it's those that object to 20 the most too
It actually criminalises those that were driving safely to start with.
