Wardrobe Lights
26 Aug 2007
Lancashire
Hi
I have "inherited" 3, 12v, 10w halogen wardrobe lights without a power supply.
I'd like to use them, regardless of there now being LED equivalents, simply because the lamps fit the holes in the wardrobes and newer alternatives dont.
Obviously I will be powering via the mains and so can anyone recommend a suitable transformer / PSU for the lights.
C.
Hello,
Thanks so far...........
I'd like all 3 lamps to be powered from one PSU / transformer.
Yes I can still get the bulbs
Crakkers - check the rating of your door switches for inductive loads if you intend to go with Winston's suggestion of a transformer, rather than secure's electronic transformer.
Thanks all.
I prefer secures suggestion so far.
C
Bad idea. Not recommended for more than one light as they will cause radio interference with long cables. Also they tend to fail and replacement costs out way any saving.
I replied to his "removed" post:
Also SMPS tend to fail whereas transformers tend not to. Any saving in initial cost is lost in the cost of replacements.
That is why, of the many electronic transformers I installed in my Mum's house many many years ago, only one has ever failed...
http://shop.ibl.co.uk/products/97-410600.aspx
I replaced it with what I had available at the time, an Osram electronic transformer & it is still going strong.
https://www.osram.com/osram_com/pro...n-lamps/halotronic-compact-htm,-htn/index.jsp
