Waste from Shower
Yes that is right, just looked at the place I bought it from and it had a link to the manufactuer, both are based in Middlesbourgh.
What would you recommend i do? Buy a new one (would rather not because of cost) raise the shower and put a trap in? or anything else?
Thanks for the advise
either raise or cut a hole in the floor.
cutting a hole i prefer as it keeps the tray low. but that depends on your joists and where your waste joins up to the stack
Cheers Seco, i have got parts of the floor up so will see if i can get away without raising shower as it is actually a new installation (turning an old bedroom into an ensuite, i have planning permission etc) it is next door to the bathroom so can feed the supply pipes through no problem. However I have to run the waste about 2 metres down a stud wall that separates the bathroom to the new en suite then out the back of the house to connect up to the soil pipe. it is more tricky than I first thought, that is why i started asking advise.
