When you reinstate that decking, I would create an easy-to-remove inspection panel which you can regularly lift out, check the drain and hose through with clean water. It's also good practice to occasionally fill the kitchen sink with clean, hot water and let it go, to flush waste pipework out - better than reaching for the dreaded 1-shot, sulphuric acid drain cleaner
