I agree but we've had it for 24 years now and Mrs M wants a change.Current kitchen looks great.
We particularly want to keep a straight line to the block of units. We had to drop that separate unit down on the last kitchen but I don’t think it will work dropping the middle unit of three.Can you add a narrow unit underneath the RSJ -a spice cabinet and cut it down to fit under the rsj
Top right corner of your photo on the top of the unit looks like a leg u hook thing
How long have you been married? Get rid of Mrs Mottie, time for a change!
And keep the kitchen!
Andy
That’s a bit of plinth that needs to go back on…..Top right corner of your photo on the top of the unit looks like a leg u hook thing
40 years this year and that’s after a six year road-test.How long have you been married?
An embarrassing admission.
Apart from showing Mrs Mottie how big six inches is when she asked, no.Now you've broken the seal, anything else that has been weighing heavy on you, that you could unburden yourself of?
Don't steels need to be enclosed in plasterboard for protection from heat in the event of fire?Edit: Just realised too, when we were boxing in the RSJ, to keep things as high as possible, I glued a strip of plasterboard onto the bottom of it before the angle beads went on and it was plastered. May be another 10-15mm to be gained there. Every little helps in this case!
Maybe nowdays but don’t think they did 25 years ago. Anyway, due to my schoolboy error in measuring, I won’t need to touch that now!Don't steels need to be enclosed in plasterboard for protection from heat in the event of fire?
After my dog walk this morning, I drove straight to Magnets armed with my tape measure and measured the unit in the showroom from top to bottom. It was, as I was told, 2118mm. However, the 2118mm on my tape measure wasn’t the same as I have been checking indoors. I had been checking against 2180mm. What a f'cking idiot! That'll fit easy. Even with the cornice it’s still only 2150 so may be able to squeeze that in too
The units are 2118mm tall excluding the top trim and I only have 2100 from the floor to the bottom of the joist.
Yes but that’s from the top of the finished floor height to the underside of the RSJ and another careful measure made it 2110 so only 8mm to find. As said, the distance is from the finished floor height and that floor is made up of LVT click-fit planks on12mm ply on top of the floor boards s there’s at leas 17mm there. Add to that I can gain another 15mm if I had to remove the plasterboard on the underneath of the joist and there is also the possibility to reduce the height of the units by shortening the legs and trimming the end panels. It’s a lot more doable than when I was measuring it wrongly at 2180mm. If it was in feet and inches, I wouldn’t have made that mistake. Bloody newfangled metric measurements!I'm still a bit confused. I thought there was only 2100mm to the underside of the joist.
