NGBod said:I fitted an external WC sensor to my Biasi M110 combi.
I couldn't locate a Biasi sensor and rang Biasi technical who at first told me Biasi's didn't support this feature and asked why I wanted to use it. They then said weather compensation is only of use in countries like Sweden.
Later I noticed in the manual that the resistance curve for the weather comp sensor was the same as the heat exchanger NTC's on the Biasi so used one of them. (Cheap)
So far it is working well. I chose a fairly steep compensation curve due to having an old house with poorly insulated solid walls. With an outside temp of 15 degC the boiler sends water to the rads at about 30 degC but with an outside temp of 5 degC it sends the water out at about 60 degC.
Dave
Excellent tip! Thanks for the info.
I couldn't locate one either. Biasi told me they didn't supply the external temp sensor in the UK because it wasn't needed in our climate. I wasn't convinced about that logic and now that I'm having to nudge up the boiler temp as the weather gets colder I know I was right. Now how about an indoor sensor that works the other way? Can it be done??
