If by wooden noggins you mean solid bridging, it's there to reduce bounce in the floor.It's not there to reduce twisting of anything, following the lead of Hawkeye was never going to be a good idea.
What "very common old building technique" are you referring to?... a very common old building technique.
Kind Regards, John
I think that asking or taking advice from Hawkeye is worse than a bad idea that is very bad indeed.unusual choice of grouping, is it a bungalow? I have solid floors but was thinking about insulating between joists upstairs when I rewire my house as the ceilings will be coming out. Not sure how much better it will make it though what do you think?
If you revisit that reply and think about it you might realise something apposite.Don't understand. Reflect only has one meaning.
It isn't, actually...Hawkeye, a person of whom it is very difficult to work out what he is good at.
It might benefit the turnover of cable makers.Insulating in-between levels of a standard house has little to no benefit
Very true it definitely wouldn’t hurt!It might benefit the turnover of cable makers.
As I said. But there’s better ways to do it if that’s your aimIt helps prevent the transmisison of SOUND between floors.
Nozzle
Well, I tried it when we built our extension. Between our kitchen/living room and our son's bedroom/living room upstairs. I could not have got any more insulation in. Did it sound proof the ceiling? Did it hell. Most sound is transmitted through the joists. You have to mechanically separate the floor upstairs and the ceiling downstairs (alternating joists) and this has to be done for most people at the time of building.It helps prevent the transmisison of SOUND between floors.
Nozzle
