- Joined
- 27 Jan 2008
- Messages
- 24,903
- Reaction score
- 2,877
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
It seems tradition has resulted in some names which no longer describe the item. The bulb was a bulbous shape, but then we got the folded tube.
The ballast now replaced with a HF switch mode device which is not really a ballast.
The transformer also replaced with a switch mode device at least it's called an electronic transformer to show the difference.
The MR in MR16 refers to the reflector so since most LED lamps to not have reflectors they are not MR.
The driver is a real problem as it described a current regulating device used to power runway lights and LED's and now anything which is used to power an LED even if voltage regulated seems to be called a driver.
Even the word lamp. We had a spigot on the wall which the tilley lamp fitted on. The thing which gave out the light was called a mantel, whole item was a lamp. Now since the thing giving out light is not bulbous we have started calling that a lamp and the whole item a fitting. Except with auto trade. A head lamp comes without the bulb that's extra.
And as to low voltage, at least we do have a definition pity lighting manufacturers can't read BS 7671?
Sorry to shovel it on but didn't have a spade!
