Maybe, maybe not. Probably not.
When you do a scoring cut using a plunge saw and guide rail it is imperative that the guide rail is clamped firmly to the material before and during the cuts. This is to ensure that the guide rail doesn't move at all between the two cuts. Normally, the rubber grip strips at the bottom of a guide rail are sufficient to hold the it in place for a single cut, but it is very easy to disturb it even by lifting the saw off the rail or just sliding it back to the.start position. Believe me, this I know from personal experience. In this scenario the scoring cut is made first
Trying to reproduce this on a table saw is fraught with problems, but I think if you insist on doing it that way, then think on terms of making the scoring cut first. Not last, where you risk having the almost cut through section just snap off as you handle it. All I'd say is don't expect to get a clean cut all the way through without any steps. You may succeed, you may not.. Are you sure that you aren't just trying to use the table saw just because you have it?
Now we know this is a rip cut (my earlier comments were assuming a cross cut, doh!), just why is it necessary to get a perfect cut? Most times when you rip worktops down in width the rip is going to end up against a wall and have some form of tiling, backsplash or upstand which covers the edge, and always a silicone joint which will also help hide minor discrepancies. Walls are rarely straight, so it's not productive a lot of the time to be ultra precise doing these rip cuts (but it most certainlty is productive to seal the cut edges, even if they get hidden afterwards). It's only on cross cuts at any exposed ends of a worktop that the cut needs to be near perfect (masons mitres are dealt with by jig and router). That's so it can take the laminate cover strip. TBH before I had a plunge saw when doing such crosscuts I'd just cross cut slightly oversize then use my 1/2in router, 30mm guide bush, 1/2in diameter cutter and the outside edge of the worktop jig (clamped across the end of the worktop section) to make a perfect cut edge. The offset from the jig is a little awkward (8.65mm), but doable
