D
Deleted member 174758
Just not on a laminate surface or edge...glad its sorted lol nicks pencil marks all part off the individuality
Yes that is what I have just tried and it did not work, not enough downward pressure and too much scope for movement against the fence (blade bending ? ) resulted in a very bad score. also with the work top face down the blade is going the wrong direction for a goo cut. So yes it was indeed fraught with problems. It was an experiment.but I think if you insist on doing it that way, then make the scoring cut first. Not last,
Actually the scratch problem was the 1 and only rip cut and the rest are all cross cuts.Now we know this is a rip cut, just why is it necessary to get a perfect cut?
Well I tried gnawing through it but it left a load of teeth marksAre you sure that you aren't just trying to use the table saw just because you have it?
yes forgot it was laminate rather than oak blockJust not on a laminate surface or edge...
With a long piece you really do need a full length outfeed table so that the workpiece is fully supported as it comes off the saw - a roller support won't do (alright for ripping solid timber down before it is planed 4 sides, but otherwise not that good). As to scope for movement against the fence - that sounds as though you aren't supporting the material well enough on the infeed side as well as not providing any pressure against the fence; the pressure applied as the piece goes across the saw must be diagonal, both forwards and towards the fence, simultaneously. This is a lot easier to achieve with a full size table saw where you ren't additionaly attempting to support the material (which is what I suspect you are attempting to do) than it is with a portable saw such as yours. I own a DW745 (the predecessor saw to yours) and frankly I wouldn't have attempted the cut on it unless I built a flat infeed and outfeed tables first - in point of fact before I had a portable table saw or guide rail saw I used to do these cuts from the underside of worktops using a Makita 190mm saw and a 72 tooth ATB (alternate top bevel) or TCG (triple chip grind) blade with little diffioculty. As discussed, the key is to have the correct blade and top bear in mind that in many cases the cut will subsequently be hidden, so a portable saw with a thick enough saw blade (2.2 to 2.5mm) and enough teeth (48t on a 165mm blade) will do the jobYes that is what I have just tried and it did not work, not enough downward pressure and too much scope for movement against the fence (blade bending ? )
Stanley knives are not up to the task, even if you use a laminate scoring blade in one. The horizontal grade laminate used on post-formed worktops is basically Tufnol plastic and very toughI aslo tried first scoring with a knife brand new Stanly blade and that in itself caused its own chips before i even when near the saw (tried different methods and pressures - still chips
Which is pretty much where we startedThe best result so far is from the circular saw ( after my initial not square cut in the picture). Its actually the same quality cut as i am getting from my 60 tooth blade on my table saw which still gives very tiny chips in places.
If I need to cut some in the future I will get myself a 2.4mm kerf 60 tooth for the circular saw
Yerp, doesn't polish out as well - despite the assertions of the Pink Stuff spammer we had earlier this week!yes forgot it was laminate rather than oak block
Yes I have a flat out feed and used it but only the table itself for infeed. It was only 500mm wide x the worktop depth 600mmWith a long piece you really do need a full length outfeed table so that the workpiece is fully supported as it comes off the saw - a roller support won't do
I was applying pressure but not enough,As to scope for movement against the fence - that sounds as though you aren't supporting the material well enough on the infeed side as well as not providing any pressure against the fence; the pressure applied as the piece goes across the saw must be diagonal, both forwards and towards the fence, simultaneously.
Correct no infeed support apart from me.This is a lot easier to achieve with a full size table saw where you ren't additionaly attempting to support the material (which is what I suspect you are attempting to do)
The circular saw method was the best cut in the end, even with a 24 tooth compared to my table saw with 60 tooth.2 tooth ATB (alternate top bevel) or TCG (triple chip grind) blade with little diffioculty. As discussed, the key is to have the correct blade and top bear in mind that in many cases the cut will subsequently be hidden, so a portable saw with a thick enough saw blade (2.2 to 2.5mm) and enough teeth (48t on a 165mm blade)
Another thing I have noticed while cutting kitchen unit chipboard and other coated chipboards is that some chip more than others.Makita 190mm saw and a 72 tooth ATB (alternate top bevel) or TCG (triple chip grind) blade with little diffioculty. As discussed, the key is to have the correct blade and top bear in mind that in many cases the cut will subsequently be hidden, so a portable saw with a thick enough saw blade (2.2 to 2.5mm) and enough teeth (48t on a 165mm blade) will do the job
