Thank you all so much for your input. I have scrapped the last revision as from your comments there looked to be too many mistakes.
Regarding where the feed/expansion connects to the system, I am somewhat limited on what I can do with it. My only options are to connect it to either the feed or return near the HW tank. To run another pipe back to the boiler room would be a massive job and affect the kitchen and living room, so I'm trying to avoid this if possible. There is not enough room near the tank to introduce the pump.
I have looked at the Honeywell Sundial Plans and revised my planned system to become an S-Type system (I hope). I have taken on board as many of the comments as I can, the only thing that I haven't done is position the vent/feed before the pump. I do however have it entering the system on the feed before the valves. In the event of an overrun and both valves being closed, the system would just vent into the feed tank. If this system is still not correct, maybe it could it be fixed by adding a bypass to the system at some point.
Is this plan OK, legal and safe?
