B
Bodd
On our walk tonight see a 1500 Tolido..... Sounds Somthing like it
Dolomite was the upmarket sporty version of the Toledo. I had a chocolate brown one for a while, nice comfortable car.On our walk tonight see a 1500 Tolido..... Sounds Somthing like it
£20 quid? Big deal. Wot does k.p.a. mean
Means £20,000 per annum I presume.
...... £20k p.a. to insure in the eighties
Saw a Triumph rocket t'other day, mahoosive.
Strange as I knew people in the 70's that got a lot more miles out of them then. The only related make I drove was an MGB GT. Ex my brother. I'd built a Spartan from scratch fitted with a rather tuned up 2L Ford engine and got fed up with the engine mountings snapping so we swapped. It went lot higher mileage than you have mentioned but was showing signs of the engine needing work but I do drive rather hard. 80 odd thousand from memory and probably not well serviced for part of it's life.(Brother at least)
There was a period, don't ask me for a date when oil got well ahead of engines in as much as they lasted way longer than they did but I would say that was more like the 90's. Fiat were the first to take advantage of that. High performance sports car with a smallish engine. It had to run on ordinary oil for a number of miles first to run it in. Now they all take advantage of it. You may need a new Ford gear box at 60k these days. Probably higher if all motorway driving.
A what ???????
Triumph Rocket t ? t I assume = three
the 2.3 motorcycle ?
I remember that engine, SAAB put in in with the front of the engine at the bulkhead. But it wasn't half of a V8, it was its own design, a slant 4. OHC engines were tall and put in at 45° otherwise you wouldn't be able to see over the bonnet.
I believe it was the 1850 engine from the Dolomite that Saab used
Myth. To reassure saab buyersMuch modified for reliability was what I understood when I had a SAAB.
SAAB used the engine years before Triumph used it.I believe it was the 1850 engine from the Dolomite that Saab used
Myth.
Kinell. My humour is lost on G.D. I wonder if Fry and Laurie are still looking for a third..?
