Where do I get a double light switch from?
OM2
18 Jan 2007
Not sure if this is a dumb question or not
I've searched everywhere and can't find a double light switch
I need one that is double the size of normal - 2 gang - I think that's what it's called??
All I can find is a double switch on a single gang
No good if you're trying to replace a double
I've tried amazon, ebay, diy.com, screwfix, google search - nothing!
Am I searching for the wrong name??
This HAS to be the explanation - double or dual length light switches can't have disappeared from the planet!
OM
How many switches do you need on it? Four and six switches come on a two gang plate. If you only need two, uh, grid switches?
If you need two switches to control two lights you need a two gang switch. If you need two switches that may also control the lamps from another switch, then you need a two way, two gang switch.
They haven't disappeared. Its just your Google search terms are, how can I put it without being offensive? Aah. Crap! :D
Unless of course you have those fat bodied switches were one will fill a single plate.
Do you mean that you have a recessed box in the wall which is similar in size to a double socket? If so, does it have a dividing piece in the centre? Picture would help. Ignore terms such as gangs and ways as these are confusing your descriptions.
You need a 3 gang grid plate.
This measures about 85 x 145 mm. This has three spaces for three switches.
You can get two switch modules to fit the plate. And a blank module to fit the unused space.
Crabtree and MK are the most reliable for this. Electrical wholesaler is the best place to get these fittings.
