whirlpool 6th sense washing machine motor burnout?
Just because the other motor is perhaps a different make does not mean you can't use it, if it physically fits the mountings and the belt groove pitch and motor plug are the same. Appliance makers often source motors from more than one manufacturer but they have them made to their own spec.
The 7 pins may indicate a centre tapped field coil but not always. There is normally a thermal overload cut-out in series with one of the brushes but sometimes there is also a connection direct to the brush, probably for the diagnostics circuitry.
thanks
turns out they were different models 10561 10761
motors different mountings
timer and door switch are identical
all seems well but i stopped it before end of cycle
i mixed up the belts
one seems a little loose so i fited the other one but i want to be sure
thanks again fidom
