masona said:
last 2 car I've owned had a management system failure costing £££££.
But this is my point: the rugged old diesels of old had a big lump of iron for a block, basalt columns for pistons and an old Lancastrian mill as a fuel pump.
However, "New Diesel" has fancy gizmos just like any petrol engine.
What is it that you have in a petrol engine that you don't have in a diesel engine that decreases the reliability?
Spark plugs? Nope, they're reliable, and you have glow plugs to start a diesel which can fail too.
Valves? Just checked and the BMW 320d has 16 valves, the BMW 320i also has 16 valves (they sell more than Mondeos now so thought that would be a good one to check!)
Pistons/cylinder design? Well the 320d and 320i have the exact same stroke and bore, therefore it won't be some "force distributed across greater area of piston" or the converse "force concentrated at kingpin" argument.
So, I would not be surprised to find out that a modern diesel offers no reliability advantage over a modern petrol.
A diesel myth, if you will!
The best way to increase availability of an engine? Increase the number of cylinders. Reliability decreases, but availability is improved as you can drive an 8-cylinder engine on 7 or 6-cylinders more easily than a 4 cylinder on 3 or 2.
