DP: had hot water off all day with no real difference. The hot water 2 port valve was definitely shut and I am checking the valves to make sure all is as it should be. As the flow and return temps are nearly up to 30degC then I think this must indicate low flow.
Agile. The boiler size of 30kW was what the local company who did the job installed. They do have a good name locally so I really don't know what happened there. I was certainly no wiser so wouldn't have questioned it if I had been asked.
I am going to apply the settings fron snb for tomorrow.
Thank you all for your contributions.
