- Joined
- 27 Jan 2008
- Messages
- 25,368
- Reaction score
- 2,982
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Now you are seeing my point, we know it does work, not how.
I don't get that diagram at all - i.e. I cannot see how it could work.
If the pipework were of similar size for the connections to the cylinder and Wallis heater were the same, when you turned on a hot tap, you'd get a roughly 50:50 mixture of (cold) water from the cylinder and heated water from the Wallis.
More to the point, what you depict could not supply more hot water than (the small) volume contained in the Wallis heater (mixed with cold from the cylinder, as above), since there is no way that it would get from the heater into the cylinder.
As you've shown it, I really don't think it could work - for reasons I explained.Now you are seeing my point, we know it does work, not how.
Not per eric's diagram, surely? Water 'rising out of the Wallis' can surely only rise into the expansion pipe, it would have to 'fall', through colder water, to get into the cylinder, and what would make it do that? I suspect that eric's diagram is not correct....Water rises out of the Wallis, permeates into the top of the cylinder ...
@bernardgreen ... maybe I'm just being dim, but I am continuing to struggle to understand how that is achieved - as I wrote to Harry, I certainly don't see how it would work per the diagram posted by eric (which is the first hit one gets with a Google search for an 'image' of the Willis system).The Willis system creates hot water externally and feed it into the top of the cylinder while removing cold water from the bottom of the cylinder.
All I can see happening is the (small volume of) water in the expansion pipe getting heated, primarily by convection, with the cylinder just remaining full of cold water.
Convection currents will cause water in the Willis to expand and rise, drawing cold water in at the bottom. The cold water coming in at the bottom, will be drawn from the cylinder, thus drawing the hot from the Willis into the top of the cylinder.
Clearly a case of "Great minds', but I'm still somewhat struggling.The hot water rising up out of the heater is replaced by cold water taken from the bottom of the cylinder. The replacement cold water cannot come from the cold water tank because if water from the tank entered the system then the level of the water in the vertical expansion pipe would rise to be above the level of the top of the water in the tank.
However, other than that (possible) tiny amount, no water has been 'lost' from the system, so there is seemingly no need for any cold water to be drawn into the Willis heater from the borrom of the HW cylinder (which, if it happened, would 'draw' some of the heated water into the top of the cylinder.
If a hot tap is turned on, what comes out will be a mixture of (cold) water from the cylinder and (hot) water from the external heater (none from the expansion pipe), but that will only remain hot/warm until the (small) volume of heated water within the external heater is exhausted.
Maybe, but I have spent most of my professional life having to be unsatisfied with such 'explanations'!Isn't the answer "it just does"?
I see no way that (at least with the arrangement we've been shown) it could 'pump' hot water into the top of a cylinder full of cold water.That is - the heating element or heated water will act like a pump.
The top and bottom of the external heater? If so, then yes, but 'so what?' - that wouldn't help the hot water to get into the main cylinder, which is what this system seems to be all about (except in those situations in which one does not need more hot water than the (small) amount within the external heater).If there was just a loop from heater top to heater bottom, would the water not "just" circulate?
Yes.The top and bottom of the external heater?
So, make the cylinder part of the loop.If so, then yes, but 'so what?
Yes, I have to accept that - I am not suggesting thatvthe Irish are deluded into believing that it works when it doesn't, but ...It obviously does work ...
I don't really understand what analogy you're trying to draw. As you previously wrote ...... and did work for the vehicles with no pump, using convection alone.
Indeed so - and not only in car engines, but entire CH systems worked on that principle. However, in that situation the water is constantly circulating, in a 'convection loop'. In what is being described here, there is no such loop, hence no circulation - and certainly no way I can see of getting hot water into the top of the cylinder (initially full of cold water) without either having a pump or else introducing the hot water into the cylinder below the top (hence all the disadvantages of having to rise through/mix with cold water before it gets to the top).... Before cars had water pumps in the cooling systems, they relied upon convection currents to circulate water up through the engine, out of the head, into the top of the radiator, then eventually back to the bottom of the engine. Water rising as it took on heat from the engine, then falling as it cooled, in the radiator.
As described, it really makes no sense to me.I see your point, but that has me equally puzzled too - unless there is some sort of valve, or restriction of some sort which is ommitted from the diagram.
Exactly. IF one fed the output of the external heater into the cylinder at some distance below it's top, then there would be a 'loop', and that would work ...So, make the cylinder part of the loop.
