Just set up an Elite 48 running latest software and added a ComIP. I have set up the ComIP & I can access it internally (LAN) via Wintex no problem.
I have set up Port Forwarding, again with no issue on the Port selected.
I can access the Panel using the Texecom Engineer App via the Internet.
However, I cannot access the Panel via the Internet. It says "Reading UDL Options" for a few seconds, then reverts to the default "Connection with Control Panel could not be established - Please check your settings and try again" error message. I am obviously initiating a talk to the panel but something is not allowing the final handshake. So...
It is possible that this is a Firewall issue on the laptop I am using. I have opened the selected Port on both TCP/UDP in and out but still no joy. I can't turn Windows Firewall off as I am not an administrator. I am using the same laptop for both LAN & WAN, so a bit annoying!
Any ideas please? Or anything else anyone can think of?
TIA
TIA
