M
mdf290
Please tell the readers what happens if the battery goes totally flat ( or that battery contact problem disses the battery ) while the alarm is set.
If a sensor sends "Battery Low" or due to no power left a sensor stops sending any messages while the alarm is set then does the panel inform the user ( who may be on holiday ) or does it set the siren going ?
The battery low warnings start when there is approximately 3-4 weeks life left in the battery at which stage the panel bleeps every 30 seconds and the orange fault light comes on at the panel.
Would YOU go on holiday when you have been given a warning beep every 30 seconds for a month or would YOU consider it prudent to change the batteries first?
But I have read your comments and explanations about the way the system functions. You might convince a prospective purchaser but you set alarm bells ringing in the minds of people who have some knowledge about what an alarm system should be.
Bernard PLEASE start your own alarm company and then produce the perfect alarm which YOU would be happy with , tick all your boxes,answer all your own queries and then sell it for £200...
I wait with baited breath to see you make ANY attempt to produce ANYTHING at all comparable to what Yale have done for the domestic market.
Why don't you go and troll your local skoda garage by telling the manager that a BMW is better...
. . . .that is the sort of thing that floats your boat isn't it?
Look you have admitted you have never installed or tested a Yale so from now on you cannot be taken in the slightest seriously.
You keep making one incorrect assumption after another. I only answer you so your answers don't misinform people,If I was only answering you personally I would tell you to grow up.
Stop taking the lazy way out Bernard by making one incorrect assumption after another.
Go buy a Yale alarm and test it thoroughly.Install it to the best of your ability taking all considerations into account. Do break in tests and then when you have done all that. Come back and report your findings.
Otherwise I cannot continue to answer your questions just to support your laziness.
