Advice please regarding the following...
Drayton Digistat SCR/RF1 Wireless Heating Control System -
This is intended to replace the Drayton manual thermostat, which is located on the outside of the ‘airing cupboard’ on the landing.
A Glow Worm Micron 80FF Fanned Flue Boiler provides our Hot Water system. This is located on the kitchen wall downstairs and is controlled by a Programmer...switching the system on/off twice daily. Life Style Model LP241,
I wish to remove the old Thermostat and replace it with the Wireless System, on the livingroom wall downstairs.
The wiring instruction for the Wireless System states: -
The SCR should be wired to the Combi boiler or central heating wiring using the correct type of cable or flex. The SCR should be wired in to replace hard-wired room thermostats.
The wiring instructions are I think aimed at the 'professional' to deter the DIY man, which in many circumstance I agree with completely. But there are those of us who like to 'know' what work is needing done to get these systems working and according to the manufacturers, they are 'straight forward to fit'.
Anyway looking at the front of the Glow Worm boiler 'electrics' there is a 'block-connector' there are 7 connectors and the wiring is as follows looking at it from left to right:-
Lp =LIVE – (Permanent)
Ls =LIVE – (Switched)
N = NEUTRAL
EARTH MAIN
EARTH PUMP –
Pl = PUMP LIVE –
Pn= PUMP NEUTRAL
Any help or suggestions would be gratefully received.
Regards
Robert Maitland
N = NEUTRAL
EARTH MAIN
EARTH PUMP –
Pl = PUMP LIVE –
Pn= PUMP NEUTRAL
Regards
Robert Maitland
