Yes the power socket is a spur not on the main ring.
I doubt there will be a massive effect on the cables themselves, the main worry would be the issue of changing them in the future, without much knowledge of CWI, is it possible to run wires through it? In other words, would I still be able to pull the wires through and replace after CWI has been installed?
Knocking the bricks out won't be too much of an issue because I had to knock bricks out and replace to brick up the hole left by the flue, this was 4 full bricks in the end. It's enough space to get some trunking in but it sounds like it might not even be worth it.
In terms of the type of insulation, the quote we've received so far has quoted Energystore BAW 18-057-S-A-UK but I'm not sure whether that's related to the type of insulation or not.
I honestly never knew about the risks of damp in houses with CWI, I assumed it was a "no brainer", every day is a school day!
The house was built in the 70s, it's a detached dormer with a damp proof course and lots of air bricks underneath that.
Edit, the quote includes having all the cavities cleared of rubble
