I have purchased a Surya Infrared 750W panel wall heater with separate stat.
I have installed a 13 amp fused spur under where the infrared wall panel heater is to go.
To this I have connected a Salus RT510RF receiver which will connect wirelessly to the Salus thermostat/programmer.
Reading the instructions for the heater it says it should be plugged into a mains socket, but the heater is supplied without a stat in it, so assumed as a stand alone wall mounted heater. Am I correct to wire the infrared panel heater, to the appropriate connections in the Salus receiver?
e.g. mains supply to supply points of fused spur, wired from load positions in fused spur to supply in receiver, then out of receiver to infrared panel heater.
Thanks in advance for your help.
