ELZ4742 said:ok, do you have an existing time clock?
the cm range have a clock and stat built in tegether so you can remove both of the old items.
from what i can gather, the original will be live (red) neutral (blu) yellow (s/live)
use the yellow & red, it matters not which way round they goin the stat,
connect the same cables in the boiler in the send and return terminals, disconect the blue.
i will advise that t &e should not be connected direct into the boiler, heat proof flex should be used instead
This also makes sense to me now, although I assume I don't need to worry about wires to the boiler as they won't change?
Thanks again for helping a dummy!
