I currently have a double oven 5.7 Kw the supply cable is 6mm 2 core and earth with a 32 amp breaker, the run from the consumer unit is about 4m to the cooker isolator the cooker connection is half a metre from that. I want to replace this with two ovens mounted one above the other one is 3.6 Kw the other is 3.2 Kw. Can I connect both ovens to the existing cooker isolator is the 6 mm cable big enough. all the calculations I have done say it is but what does the voice of experiance say. The hob is gas and there is no other socket connected to this radial circuit.
