I have just fitted a Wocester 240 rsf and having bled the system and pressurised it am left with hot water only ..no problem filling bath.. .on the central heating side the boiler fires up but within a few seconds the thermal protection trips, with the sound of v hot water/steam in the unit.
The pump I presume is working as it can be heard and when i undo the vent screw the propellers are turning freely. Even so there is no water flow present as heat can only be felt 20 cms down the pipe after minutes of the pump running.
Could this be a dicky dirverter valve, I have had faults with them in the past but always the opposite way c/h but no h/w or is there a bleed valve I'm missing near the gas/water heat exchanger..
