Da's right Sooey. The 4mbar bit is contentious though. I haven't got it quite straight who says exactly what yet, which is a task I have cos I teach the stuff!
14mbar miinimum is at the outlet of the meter, though, without a load being specified as far as I'm aware.
I've complained about standing pressures below 19mbar, and found it higher later after they'd turned it up miles away. Water in the pipes can cause the gas carrier big problems.
Until you have had the WP measured at the meter and at the boiler there is little that you can usefully do.
We need to know if there is a problem and where the problem lies!
Tony
But am I right in thinking that all gas appliances have to be specified and built to work safely with an inlet pressure as low as 14 mb?
If that is the case, do you think that the gas suppliers are trying to move the goalposts to suggest that this is all that they need to supply.
I had a long and fruitlesss chat with corgi tech the other day
Gasguru, the 5 mbar drop concerned us all. The 'transo' guy muttered something about the meter being inadequate and when I suggested moving it to just outside the kitchen/boiler area was a possible solution he looked a little shocked and said the piping (28mm) was more than adequate and that it was probably our small meter that was restricting the flow. He muttered further that our supply was only good for about 5cu/m an hour which seemed to contradict his earlier remarks.
Anyway, he admits there is a problem that needs to be dealt with on the supply side and I am not going to argue with that! I intimated that we were considering gas fires and cookers too. He paled and muttered further that we could be disconnected if the pressure dropped further which was not encouraging. Fortunately, he seemed to consider that they had some sort of responsibility to supply the required gas. Whether his superiors will remains to be seen!
