Worcester Bosch Heatslave 15/19 Intermittent Lockout
First started mid Nov 2008. Any time of day but commonly first thing am. OFTEC boilerman serviced it and told me whilst ever it restarted on the reset button it would be like trying to find needle in the proverbial. He said he could try changing parts one by one, some cheap, some not so, eventually find problem but a lot of cost involved and was trying to save me money so advised to bear with the problem, hopefully break down properly then easier to find what's at fault. If he couldn't find problem then would at least be able for him to use WB technical helpline to faultfind. I reluctantly accepted advice but when it became so regular, about 10 times a day, he suggested that I might try changing Satronic controller as this was within my novice scope. I duly did with no success but he'd mentioned the coil/solenoid in passing and I'd read an old post talking about coil probs with Electro Oil burners so I changed the coil and Hey Presto no problems for 2 months until last week when it's started again!
A couple of times a day at the moment, first thing in morning for last 3 days and once or twice later on in day. THe only other things of note
1. Oil running quite low last week when it restarted but still 100cms above sight gauge. Refilled tank, still happening so could feed be a problem (air or dirt)?
2. When I've been around on lockout there is strong and hot fuel smell from boiler. Normally little or no smell.
3. Photocell seems clean
4. Whole system is 15 years old. 2 oil pumps in that time last one 2004. New burner motor 2004
5. Danfoss 0.50 80EH nozzle
Sorry about the long description. Hope somone can point me in right direction if you've not fallen asleep already
Steve
Steve
