If it's not going to lockout then the control box is not progressing.
Pressure guage
Vacuum guage
Volt meter
Smoke pump
Flue Analiser
Knowledge of how they work helps:
CORGI what have they tio do with oil appliances!!
It is easy to dismantle the pump but now having done so what is the pump pressure when running? Have you tried the suggestion I made earlier about supplying solenoid coil with an outside supply and does the boiler now run?
You ask for help but you need to accept suggested tests and report back the result otherwise everybody is wasting time.
3 connections to coil - two parallel are the supply single one at 90 degrees is earth.
Wiring diagram on page 16. Only 'non standard' part is the motor supply from terminal 4 of the control box is fed back to the boiler to the post purge unit and then fed back to the actual motor.
For startersWhat do you need to work on oil fired boilers?
Pressure guage
Vacuum guage
Volt meter
Smoke pump
Flue Analiser
