Replacement Sterling ST40 burner is £260 + Vat
Note original post above pins 1 & 2 relate to the connector NOT pcb in control box.Pins 1 and 2 Brown and Blue as I recall didn't show any voltage.
Pins 1 & 2 on the control box are the photocell connections, but then you knew that from looking at the drawing on the bottom of the box. It's time you got someone in.
Only because someone else is doing the actual tests and I have to rely on the supplied results. If I was sitting in front of the boiler 8 days ago I can guarantee it would have been working 8 days ago.Is this one baffling you too?
Forgot to mention also although there is no voltage showing at 1 and 2 there is continuity across pin 1 on the plug in connector and L on the connector beneath showing a closed circuit on the stats etc
