D
Deleted member 174758
I suspect that the problem isn't necessarily the joint alone, but may well also be the sink cut-out. I don't like doing joints that close to a sink cutout (or for that matter any other cutout) and if at all possible I'd have done the joint so that it ran parallel with the front of the worktop in which the sink sits (in other words at right angles to the joint as shown). That said it may have been impossible due to worktop lengths, access, etc. In addition to getting the joint right, and ideally glued up and left overnight to set (because it is such a "tight" joint), the fitter should have sealed the edges of the cutout around the sink with something like gloss paint or silicone sealant to prevent water wicking through the cut edge of the worktop towards the joint
I have dealt with this sort of problem a couple of times where that has been the cause of the failure
