Where is the water supply for it taken from?
Its teed off the water supply to the concealed cistern.
No, it's not a "bit" naff.It's a bit naff though.
It's awful.
Presumably the plastic lift out piece in the back contains a water tank, which is how the required air gap is implemented.Its teed off the water supply to the concealed cistern.
You just don't run flex through a wall and have it come out and plug into a socket.Why?
You just don't.
Yes, provided it is outside of the zones (at least 60cm distance from the bath or shower).Is it permissible to have a DP switched FSU in the bathroom?
Located in the wall adjacent to the toilet, remove the supplied plug and wire into the FCU with whatever fuse it requires - use the same fuse from the plug.
