Nope, I'm afraid not, I've still got an old 1988 vintage crabtree 6000 series board. Its getting moved into the garage and replacing with a hager full of RCBO's when one comes my way 'affordably' or when RCBO's drop in price.
GODLY, does the old 'london weighting' get out as far as your location? Its very hard to say if that is a good price without knowing the going rate for sparks in the area and exactly what kit he intends to use.
Doesn't sound too bad to me, not to sure about the 5+5 board though, very little, almost no room for expansion.
you are already using 9 circuits so 5+5 is insufficient.
a kitchen ring and it is full.
what about your future electric shower? external lighting? garden socket? loft circuits? dedicated freezer circuit? kitchen appliance circuit? soke and intruder alarms?
Can you show us a pic of your meter(s) and timer and the various cables between and around them please.
I would always go for a bigger one than you think you need
Splitting a ring is not too difficult if the cables run under a wooden floor and you can lift it for access.
The electrical work is far easier than digging up the floor and walls.
guesswork?
The new regulations will shortly require all buried cables* to be RCD protected, but it is poor practice to put them all on one RCD (as the lights and freezer go off even if the fault is elsewhere) which is inconvenient, and losing the lights can be dangerous.
guesswork?
Until we see your metering setup I don't know, but I still think it would be a good idea to have a separate CU for off-peak. I haven't seen a two-tariff 17th Edition CU yet but I bet they will be rare and expensive.
can you step back a bit and take a wider view, showing both the meter and the CU?
It looks to me like you have four thick grey cables going into the CU, is that right? Three of them out of the meter to the CU, and one of them from the cutout to the CU? Some of the cables may have coloured rings round them, near the ends.
And your meter may have some buttons that you can use to make it display a meter reading at full price and a meter reading for off peak? And the meter contains its own timer? No other boxes or timers with wires going into them?)
It looks like, if you push the Orange button, it will provide power to the storage-heater circuits during the day (but at full price)
