personally I would go for two, because the twin-tariff ones are rare and expensive. See if your electrician has any preference.
I have been looking for twin tarriff ones for the new 17th edition but they are soo hard to find. Crabtree, wylex, MK and Hager all have the new ones but no retailer stocks the dual tarriff ones.
I will try a little more before i go for two which i know is more manageable.
this is what i am planning to set up is i get the dual tarriff CU. 7/5 split
Mains Switch
Lights - RCBO 6A
RCD - Peak
Cooker - 32A/30A
Living room and kitchen ring - 32A/30A
Two Rooms and hall way ring - 32A/30A
Peak Immersion heater - 15A/16A
Spare
Spare
Mains Switch - Off Peak
Storage Heater - 15A/16A
Spare
Does the above arrangement look ok?
Do i need RCD protection for the off peak Storage Heaters?
Does an RCD take up one space i.e reduces the amount of spares on the CU?
Do i need More RCBO's for an ideal setup? if so where?
Do i need Isolation between the two tarriffs?
and put your immersion heater and tumble-drier on the off-peak supply as well, it will halve the cost (roughly) if you can use then at night.
Unfortunately i cannot use any of them at night as it is a flat.
Lastly i am replacing all the sockets and switches around flat to new chrome ones. I want to know if it is ok to use a 13A fused spur for the storage heaters rather than a normal switched spur?
Thanks for helping.
Nav
