The issue is not the lack of help from this site as u need gas people - in fact gas people that repair boilers & know what they r doing. That really narrows it down. Lots of boiler repairs are done by 'have a go' gas reg plumbers. Hence the obscene reputation we have for unecesery boiler repair costs.What is the point of a site like this if it leads to a bill of nearly £400 without a fix to a problem. Had there been more support I might have been sorted now with less expense.
Personally I'm not a great believer in fans working slowly. For me they either work, stick or stop. If eg. components such as a gas valve opens, fan runs, pump spins etc every time it's powered then I'll look elsewhere.
Just looking for a bit of advice if any of you knowledgeable people could help.
I have a procombi HE85 boiler which broke down on Thursday, an engineer came out on Friday, I have no heat or hot water. The engineer has diagnosed the fault which could well be the true but I’d appreciate your opinions.
The engineer told me the boiler was a rebadged Vokera. After spending an hour inspecting it he has diagnosed a faulty fan. He talked me through the issue explaining that although the fan was getting the correct voltage it wasn’t turning as fast as it should. The fan did sound a tiny bit noisy, but not like the bearings were shot. He explained that as a result of this the pressure switch wasn’t engaging correctly. To show this he removed one of the tubes found by the fan connected to what he said was the pressure switch. The boiler fired up immediately. He said he couldn’t leave this tube off for safety reasons.
The only thing that I’m worried about is that he has estimated the cost of a fan as £245 which seems steep after looking on the net. Firstly can a fan run slow if it getting the correct voltage (I saw 244v on his meter), secondly could it be the pressure switch, or something else at fault. The total cost of the repair is £350, if this seems fine then I’ll go with it, what are your thoughts?
Ben
Get a couple of quotes............
Even I told you it wasn't the fan - and I'm not a gas fitter.
No but you have a reputation on this board for being a complete spacktard though don't you
621 thanks - proves you wrong. You just don't like it that I know more about boilers than the average gas safe 'plumber' who knows practically 'nowt'.
That's if the windings are shot and you'll get sparking and an imminent failure.
You are my hero Tony.
We`d all be - cuz none of this would exist[if the internet didnt exist you'd be stuffed
including a skull cap ?[
I wear many hats.
i think the main problem here is that the engineer has probably mis-diagnosed ! Make sure he 100% guarantees it will fix the problem, no fix no fee, as I suspect he's missed the fault which is quite common on this model. but being a gas related issue I cant divulge.
You mean many different colour dunce caps.I wear many hats.Are you not the joe-90 who is a property developer?I've been an electronics hobbyist for over 40 years. Also own a security installation business. ....
