Safe enough for what? They regard it as safe enough for continued use.
But not for new introductions.
If it's considered safe enough for continued use without coding indicating some sort of remedial action required to remove potential danger (not just "recommend improvement") then it must be
reasonably safe. If it's reasonably safe for continued use in an existing installation then it is equally safe if you installed it today. It makes absolutely no sense to try and argue that of two identical installations one is reasonably safe because it was done yesterday and the other isn't because it was done today. Either both are reasonably safe or both are not, depending upon whatever criteria one is using to judge what constitutes reasonable safety.
Yes. They recommend that improvements be made.
Which is not the same thing as saying "This is unsafe and it should be rectified urgently."
They also forbid the introduction of any more RCD protection which would immediately require improvement.
I see no dissonance between those, nor do I see that the former means you may disregard the latter.
Within the construct of BS7671 itself, no, that's fine. But that's not the issue. You're trying to claim that it's illegal (and immoral, and probably that it makes you fat too - who knows?!).
So now you are going to try fatuous "analogies".
Only to try and illustrate how ridiculous is your broad claim of "It's not unreasonable to do X, therefore if you choose not to do X you have acted unreasonably."
Why do you think that they contain rules which go so far above and beyond what is reasonably safe that you are morally justified in taking no notice of them and telling other people to take no notice of them?
So you acknowledge that some of the rules in BS7671 go beyond what is necessary to achieve reasonable provision for safety then.
You are telling people that they do not have to do today for new work what is considered reasonable by BS 7671 today for new work, but instead can do what is no longer allowed by BS 7671 for new work.
To do that would not be reasonable, and therefore would be unlawful.
Not it would not. What would be is carrying out work which does not make reasonable provision for safety. That is not the same thing at all. And haven't
you claimed that in some cases it is necessary to do what is no longer allowed by BS7671 for new work in order to remain legal?
They are clearly not as available as 30mA ones, and the regulations do not require 10mA.
They are easily obtainable, contrary to what you tried to claim earlier. As for the regulations not requiring them, what does that have to do with it if you'fre trying to argue about morals?
30mA protection offers increased safety over 100mA (or 300mA, or none), so by your logic it's somehow morally wrong not to install a new socket with 30mA protection. Well, 10mA protection offers increased safety over 30mA, so where are your morals now if you're not suggesting that people should adopt 10mA instead of 30mA protection?
"But the regulations only demand 30mA." So what, by your arguments about legality and reasonableness?
Would it be unreasonable to install 10mA protection instead of 30mA? No. So by your own logic, that means that it
would be unreasonable to use 30mA since 10mA would be safer, therefore your 30mA option is illegal.
You're trying to use some perverted idea of what is "reasonable" in order to promote your idea that the 30mA requirement in BS7671 is somehow a legal requirement, but your logic falls apart if you then try to claim that it doesn't apply when I suggest an even higher level of protection,
Tell you what - you stick to telling your adopted fellow countrymen that their regulations/codes/advice are wrong, and should be ignored, and stop telling people here to break the law because of your personal issues with regulations changing.
Tell you what - How about you stop trying to claim that something is illegal when you can produce absolutely nothing to back it up?
And as we're going around in circles, I'm leaving it there.
