History:
Open vented Y plan system originally had a problem where CH could not be obtained. Doing the CH two wire test on the 3 port valve, showed that this was at fault. Replaced the 3 port valve with a Honeywell 4073 one at the weekend. I am an electronics tech, and also took a photo of the wiring before I swapped the valve over - I swapped one wire at a time and am confident I have not introduced a wiring problem.
The situation now is that on some occasions the CH is not tripping off. Even turning everything off at the programmer does not stop the pump/boiler running. I started to fault find but didnt get very far. What I noticed was that with the fault condition present, and the 3 port valve full over to supply CH (which I think would be the normal place for it to be if just CH had been called and was then satisfied), the orange wire was not live - so presumably the cylinder stat was feeding a live to the pump and boiler. Sometimes (but not always) switching the heating off at the programmer can switch the CH off, but the symptoms are not yet forming a reliable pattern. I should add that the boiler does trip itself out from time to time, presumably when it is internally at it max temperature, but then fires up when it cools a bit.
Any ideas please chaps. Which components can I rule in or out. What simple checks can I do.
Thanks.
Thanks.
