- Joined
- 27 Jan 2008
- Messages
- 27,771
- Reaction score
- 3,365
- Location
- Country
First question must be what do you want to run in the shed.
Using a Henley block and enclosure in house with MCB or using a non RCD protected MCB in house consumer unit with a consumer unit in the shed with RCD may tick all the boxes and where a supply over 13A is required may be only way.
However under 13A then FCU and or RCD FCU with switch FCU for lights in shed with 3A fuse may be all that is required. The requirements do change a lot depending if under or over 13A supply is required.
However more to the point is earthing arrangements. Material used in shed build and position of other houses have to be considered when deciding if to use the house TN earth or go to TT.
Just can't see the point in talking about something which clearly should be decided by the guy who is installing the system. With best will we can miss things and give totally wrong advice.
If for example some one miss read what has been said and fitted a Henley block directly feeding 4mm cable clearly this under fault conditions could be grossly overloaded. And fitting Henley Block often either means pulling DNO fuse or working live.
So if we think it is going to really be a DIY job we should not really talk about using a Henley Block and if it is going to be done by an electrician then why should we be saying anything clearly the electrician will decide what needs doing it's not up to us.
Where some one says my electrician says do this and I am not so sure I can see why talk it over but it would seem his electrician has not even been selected yet. So likely there will never be one so why suggest a Henley Block is this some form of Natural selection getting rid of DIY people?
