So, apart from the Keston No one knows any other boiler that can use mPVC flue pipe. And no one knows a non-condensing boiler apart from the Vokea SE.
We do.
You don't. If you did you would say.We do.So, apart from the Keston No one knows any other boiler that can use mPVC flue pipe. And no one knows a non-condensing boiler apart from the Vokea SE.
muggles, I was looking at the Intergas installation instructions. Max flue length is 10m. Fine within limits. The plume extension can be 7m. The normal concentric flue can run into the chimney flue. Then the thin and more flexible plume tube can run up the chimney flue to a maximum of 7m. The plume tube terminal will be secured at the top of the chimney at chimney pot. The chimney will be open so air will run down the chimney and into the concentric flue. I do not see any regs being contravened.Intergas make a chimney lining kit for this application. I believe Vokera do as well
The Keston is designed to take mPVC drain pipe.How you gonna get the drain pipe to fit the boiler ? And are you using soil pipe for the air intake ?
The Intergas is favourable as it is reliable and has a an excellent flow rate.
For you to start with, can you tell me where it is breaking the regs? You may find it is not and you may be prattling drivel.muggles, I was looking at the Intergas installation instructions. Max flue length is 10m. Fine within limits. The plume extension can be 7m. The normal concentric flue can run into the chimney flue. Then the thin and more flexible plume tube can run up the chimney flue to a maximum of 7m. The plume tube terminal will be secured at the top of the chimney at chimney pot. The chimney will be open so air will run down the chimney and into the concentric flue. I do not see any regs being contravened.Intergas make a chimney lining kit for this application. I believe Vokera do as well
The Intergas is favourable as it is reliable and has a an excellent flow rate.I have absolutely no idea where to start on this Drivel...
That is an option. It appears not to break any regs. The plume extension lengths are about the same prices as concentric lengths. The plume extension lengths are more flexible.So why don't you just go and do it then?
It seems few have experience here of these sorts of flue arrangements. Dannyboy may say he has - but hasn't really. He says those sort of things.![]()
I know when I see a shifty looking fella. Dannyboy it is Saturday evening get down to the pub. Relax. Life is not as bad as you think it is.So you don't know then. Oh dear.
