Quite. As I wrote ...I was assuming you meant correctly wired ones, since the discussion was around conformity to the standard. If not correctly wired then all bets are off, as idiocy has no limits.
A valid point, but how far can/should one go? It is not impossible that a plug could be sufficiently 'clumsily wired' that there was "a loop of bare conductor lying outside" (or sufficiently close to the outside so as to be touchable by a finger tip).
