ahh ok brain fade the dewalt is a work light not a line indicator
No.
Its both.
Thanks.
So what are peoples recommendations currently on the market?
Hi James
Table saws are incredibly accurate if it's a good machine and properly set up and provide a similar finish to a mitre saw when using comparable blades. They are also more versatile and customisable than mitre saws, but far less portable of course. If a person went into a shop to buy a mitre saw for say, £150, they'd expect it to be able to cut accurate mitres, but that is far from reality and it's a common scenario. It's actually very hard to calibrate a saw to cut a perfect 45 degree mitre. By perfect, I mean picture framing accuracy or those needed for fine furniture. For many precision applications, a shooting board is required, which is where you use a perfectly calibrated jig and plane the angle until it's perfect.
My first question would be, what do you intend to do with the machine and what kind of accuracy do you feel you need?
Here's where we get a divergence in requirements. You can use a table saw, providing that the length of the materials you want/need to use isn't more than the length/width of the shed or garage you are working in, although TBH unless you are absolutely minted and can afford an industrial sized panel saw the physical limit in terms of length will really be no more than 3 or 4 feet, In crosscutting terms that makes the average table saw useable for small-scale furniture, and that's really about it. TBH, if you need to crosscut joinery timbers, door casings, skirting boards, architraves, decking, planking (floor or shed), fencing, etc, etc - in fact anything likely to come in lengths above 1.5 metres - then the best way (indedd the only practicable way for the vast majority of folk) is going to be a mitre saw of some description. I assume that the OP intends to use his saw for a wide cross section of work including hoisehold tasks - and that makes the mitre saw the better choice.I use my table saw for everything - the mitre saw rarely gets used, but I invested some time to build jigs and sleds.
Thanks.
Incidentally, their "special ability" of cutting metal can be accomplished with any saw as long as you have the right blade fitted.
Unlikely. Speeds not correct.
Have one in my work shop and no machine that cuts wood will match it.
Let's get something straight here - it isn't the saw that's special, but the blade. Stick that blade on another similar sized mitre saw which has variable speed and you'd certainly get similar or possibly better results. In design the blade is very similar to some of the metal-cutting blades that you can get for 14in portable metal saws. Whilst I don't like doing it I have from time to time used my small DW saw (a DW777 which has variable speed) to cut aluminium profiles. I use a fine tooth (216mm, 108t) negative rake blade with Trendilube blade lubricant, with the speed turned down and the cuts are excellent - good enough for inferior fit-out world. Cleaning the saw out afterwards (to ensure that swarf doesn't scratch future polished timber pieces I cut) is a chore - and is the main reason I don't cut metal on it so often.Unlikely. Speeds not correct.
